I need to create a python script (or model) that would first rename all the feature datasets in a gdb. The feature dataset is in a set format and I need to change the prefix of the dataset.
For example: from "H2611111:xxx" to "gen26_xxx" - where xxx is the string that I need to keep and prefix of "H2611111" is a constant that I need to replace with "gen26_".
Once this is completed, I would then need to rename each feature class inside each renamed dataset. The feature classes needs to be prefixed with the newly renamed dataset separated by an underscore.
For example:
in dataset gen26_xxx:from "test1" to "gen26_xxx_test1" from "test2" to "gen26_xxx_test2" in dataset gen26_zzz:from "new1" to "gen26_zzz_new1" I am using ArcGIS Desktop 10 and 9.3.1.
For example:
