I am very new to python. I am using ArcGIS 10.0. I am trying to batch reclassify rasters in a folder and put the outputs into the same folder but with a new name(trying to do this using outputPrefix). this is the script I made:
import arcpyfrom arcpy import osfrom arcpy.sa import *inputDir = "E:\BLSK_HSI\practiceLC"outputDir = "E:\BLSK_HSI\practiceLC"outputPrefix = "Rec_"rasList = arcpy.ListRasters()for raster in rasList: reclassField = "VALUE" remap = RemapValue([[11,1], [21, 5], [22, 3], [23, 2], [24, 1], [31, 6], [41, 3], [52, 3], [71, 3], [82,3], [90,4], [95, 4]]) outReclassify = Reclassify(raster, "VALUE",remap, "NODATA") outReclassify.save(outputDir)and I get this error message:
Start Time: Wed May 13 12:06:07 2015The input raster minimum (-3.1652371883392334) is out of range.To ensure a correct reclassification, edit ranges or use a different precision settings in the Reclassification dialog box.The input raster maximum (4.0050506591796875) is out of range.To ensure a correct reclassification, edit ranges or use a different precision settings in the Reclassification dialog box.ERROR 010414: Error in creating a Raster from a geodataset.Failed to execute (Reclassify).Failed at Wed May 13 12:06:07 2015 (Elapsed Time: 0.00 seconds)I calculated statistics, built pyramids, etc. Is there something inherently wrong with my code?
