I'm trying to create a map that essentially has two maps on top of each other (chosen from many map choices) at the same time. One of maps will have an opacity slider. Should I be trying to use two basemaps? or should I be adding them as layers? What is the best way to go about doing this?
It should let there be an effect like this with the first map showing through the second.
