Preface: I'm unsure if GIS or math is the correct community for this question.
I have a set of 8 WGS84 latitude/longitude (degree) pairs for which I need to find the weighted average of.
To prevent things like the dateline causing massively warped averages, I'm converting from WGS84 into ECEF Cartesian (X, Y, Z), weighted averaging those coordinates, then converting back to a WGS84 latitude/longitude (degree) pair.
The problem is that this produces an incorrect result - the latitude seems to 'drift' the further from the equator you are.
The conversion algorithms used (from WGS84 to ECEF, then ECEF to WGS84) work as intended and produce accurate results. The problem appears to lie with the weighted averaging of the Cartesian coordinates - I'm not sure why this is.
Question: How do I produce a weighted average of a set of Cartesian coordinates that, when converted back to WGS84, will not cause the latitude to drift?
Notes:
Notes:
- Naively weighted averaging unconverted WGS84 latitude/longitude pairs produces the correct result (unless the set crosses the dateline, for example).
- As a test, I converted the naively weighted averaged WGS84 lat/long pairs to and from ECEF, and this produced the correct result, which means it's definitely something to do with weighted averaging the ECEF coordinates and not the conversion algorithms used.
