autopan with openlayers 3.10 and popover
I have a map made with ol3.10, there's an OSM layer and a GeoJSON layer with some points. I added an overlay with bootstrap popover to have popups that show points properties. At this point the problem is the popup position so, starting from this example, I can get popups with autopan function, but now the popup is split into two
The problem is that my part of code related to the popup content is different from the example. In the example there is
var content = document.getElementById('popup-content');and the popup content
content.innerHTML = 'You clicked here:
;Instead, in my map the the popup content is
var feature = map.forEachFeatureAtPixel(evt.pixel, function(feature, layer) { return feature; });if (feature) { $(element).popover('destroy'); popup.setPosition(coordinate); $(element).popover({ 'placement': 'auto top', 'animation': false, 'html': true, 'content':''+feature.get('nome')+'
}); $(element).popover('show');} else { $(element).popover('destroy'); }})How can I solve this?
