Autonumbering using ArcGIS Web AppBuilder?
I work for a water utility division and we are using ArcMap 10.1 with attribute assistant. I used the AutoNumber method to auto increment and populate a field with the next highest integer. Unfortunately this method does not seem to work in ESRI Web AppBuilder. Anytime I edit my layer and create new fields using the Editor widget provided by Web AppBuilder, the value of the AutoNumber field is set as 0. However, it works perfectly through the Editor session in ArcMap. Is there a way to make it work through the Web AppBuilder ? Or is there another option to auto populate a field when using Web AppBuilder and considering daily updates ?
