AutoDesk Infrastructure Studio cannot access Map Server (Windows + IIS)
After restarting the entire server I continue to get this error when accessing any mapagent service (e.g. http://myserver/mapserver2013/mapagent/mapagent.fcgi?SERVICE=WFS&request=getcapabilities). Although the error does a good job at suggesting the problem there is no help for how to actually fix the problem. I suspect Map Server is not running...but how do I confirm and fix that?
Problem: Cannot establish connection to the Infrastructure Map Server.
Possible Causes: -Your session has been idle for too long; -Infrastructure Map Server is no longer responding; -Internet connection problems.
Solution: Restart your application / session, restart the Infrastructure Map Server service, or contact with the server administrator.
Also, when I perform Site Authentication in Audodesk Infrastructure Studio I get an error saying:
Unable to connect to Map Server. Please ensure that the server process is running and firewall rules have been set correctly.
I don't know what the server process is called. I see nothing related to autodesk/mapserver/mapguide under services.
