I would much appreciate some help to try to have the data as I need to have it.I have many polygons which represent different areas (with different plant species in each of them).
I want to “link” some information to the polygons in order to later be able of seeing which kind of vegetation is in each of the areas (or polygons).
I attach an image so that you can see better what I am trying to explain and do.
The attribute tables of all the polygons are like shown in the picture, and I would like to add the information there is in the excel table.
In each polygon I want to have the information corresponding to the row belonging to the area (as you can see each area has a number and correspond to a specific polygon).
Then, in each polygon should have the same amount of species (all of them) and the information which will be specifically belonging to the area (or polygon) which is based on the numbers (1, 2, 3 or 0) which correspond to the abundance of each of the species in each area.
After, I will need to select the different areas or polygons by if they have 3 of Acer campestre, or 1 of Calluna vulgaris…. For example when selecting by attributes to select: 2 of abundance of Acer campestre species and then all the polygons with this characteristics to be in another colour.
I hope you understand it and can help me with it!
