Attribute Inspector for points - JavaScript API
I am attempting to get an application working where editors can click on a point feature and edit a form. I need the form to have a save button that when clicked will apply the edits to the feature.
I am selecting the point/s using an envelope. Is there a way I can tell what feature I need to apply the edits to on my save click event? I would like to store the edits to a feature as fields are changed and then only save the edits to the feature class with the save button.
I am trying to use this example to understand the edit saving and then the feature save. Attribute Inspector
Here is what I am working with right now. I am grabbing the point features within an envelope:
function initEditor() { var featureLayer = layersFS[1].layer; var selectQuery = new Query(); map.on("click", function (evt) { var centerPoint = new esri.geometry.Point (evt.mapPoint.x, evt.mapPoint.y, evt.mapPoint.spatialReference); var mapWidth = map.extent.getWidth(); //Divide width in map units by width in pixels var pixelWidth = mapWidth / map.width; //Calculate a 10 pixel envelope width (5 pixel tolerance on each side) var tolerance = 10 * pixelWidth; //build query filter query = new esri.tasks.Query(); query.returnGeometry = true; query.outFields = ["*"]; //Build tolerance envelope and set it as the query geometry var queryExtent = new esri.geometry.Extent (1, 1, tolerance, tolerance, evt.mapPoint.spatialReference); query.geometry = queryExtent.centerAt(centerPoint); featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) { if (features.length > 0) { //store the current feature for (var i = 0; i < features.length; i++) { updateFeatures.push(features); } //map.infoWindow.setTitle(features[0].getLayer().name); map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint)); } else { map.infoWindow.hide(); } }); });Then I am planning to update the specific feature with the save button:
saveButton.on("click", function () { //need to figure out how to get the current feature with the save click, //the envelope may return 1 to many records and I need the current feature updateFeatures.forEach(function(entry) { updateFeature.getLayer().applyEdits(null, [updateFeature], null); } )}); ///////Need to apply similar logic as save button click but this will update the current feature in the updateFeatures[] attInspector.on("attribute-change", function (evt) { //store the updates to apply when the save button is clicked updateFeature.attributes[evt.fieldName] = evt.fieldValue; });What is the best way to determine what my current feature is in the info window that is being edited?
Thanks for any advice!
