I have a large ESRI file geodatabase, that I loaded into QGIS with no problems. If I look at the attributes tab in the properties dialog, the fields are as they should be.
One of the fields is supposed to have small integers. If I try to symbol by this attribute, it gives me four levels: 10005, 48255, and 152528, but almost all of the features are missing the attribute. I cannot open the attribute table without QGIS crashing. Here's a screenshot of the file with the supposed symbology.
If I save the .gdb as a shapefile, then the attributes are properly coded and assigned. Here's the shapefile symbology.
It seems as though there is a problem with how QGIS is handling the attributes table, but that filedb is all right because the shapefile export is fine. I would file a bug report, but I'm wondering if the community has a known workaround or things I could check.
session info
OS X 10.10 YosemiteQGIS 2.8.0GDAL/OGR1.11.2
session info
