ArcSDE to Shapefile Async in .NET
I have a question about exporting an (versioned) featureclass stored in a ArcSDE geodatabase to a shapefile with VB.Net. I've created the code which I think should work fine, but ArcObjects "says no", accompanied with the message that the sourcefile (the ArcSDE featureclass) could not be found.
As said I have an featureclass in an ArcSDE database and I want this to export to an shapefile for local use. Previously I used the IExportOperation.ExportFeatureClass method for this operations, but due to limitations of this method I want to rewrite this. Following the ESRI documentation the next best thing is featurclass to featureclass or Copyfeatureclass.
The main goal of the source code is:
  • Async, not the geoprocessors itself, but there are several tasks which use the procedure. The problem does even exist with a single task (the others are turned off for debugging purposes). Each task has its own workspace
  • A local copy of the ArcSDE featureclass
Both Geoprocessors need an path to the sourcefeatureclass and target shapefile. The target is not a problem (it's local, so easy to retrieve), but the devil is in the source. How do I connect the Geoprocessor to the versioned featureclass in the ArcSDE.
The documentation said I should create an SDE Connection file, so I did.
Public Shared Function createSDEConnectionFile(Location As String, SDEFileName As String, ServerName As String, DabaseName As String, ServiceName As String, _ UserName As String, Pwd As String, VersionName As String) As String Dim GP As IGeoProcessor2 = New GeoProcessor Dim parameters As IVariantArray = New VarArray If Not SDEFileName.EndsWith(".sde") Then SDEFileName += ".sde" If File.Exists(Location & SDEFileName) Then File.Delete(Location & SDEFileName) parameters.Add(Location) 'folderName parameters.Add(SDEFileName) 'FileName parameters.Add(ServerName) 'serverName parameters.Add(ServiceName) 'serviceName parameters.Add(DabaseName) 'databaseName parameters.Add("DATABASE_AUTH") 'authType parameters.Add(UserName) 'username parameters.Add(Pwd) 'password parameters.Add("SAVE_USERNAME") parameters.Add(VersionName) 'versionName parameters.Add("SAVE_VERSION") 'saveVersionInfo Dim result As IGeoProcessorResult2 = Nothing Try result = GP.Execute("CreateArcSDEConnectionFile_management", parameters, Nothing) Dim conn_file As String = result.GetOutput(0).GetAsText() Return conn_file Catch ex As Exception Throw ex End Try End FunctionAnd I used this file to create the workspace for the Geoprocessor, as explained by the ESRI documentation
Public Shared Sub DBFC2FC(ByVal SourceName As String, ByVal TargetName As String, ByVal TargetLocation As String, ByVal OutputM As Boolean, ByVal OutputZ As Boolean, ByVal SDEFile As String) Dim GP As IGeoProcessor2 = New GeoProcessor Dim gpParams As IVariantArray = New VarArray Dim ZFlag As String = "DISABLED" Dim MFlag As String = "DISABLED" Dim TargetPath As String Try GP.ResetEnvironments() GP.SetEnvironmentValue("workspace", SDEFile) TargetPath = DOTNETLib.Win32Api.GetLongPath(DOTNETLib.Win32Api.DirectoryFormat(TargetLocation)) If Not TargetName.EndsWith(".shp") Then TargetName += ".shp" If OutputM Then MFlag = "ENABLED" If OutputZ Then ZFlag = "ENABLED" GP.SetEnvironmentValue("OutputZFlag", ZFlag) GP.SetEnvironmentValue("OutputMFlag", MFlag) gpParams.Add(SourceName) ' in gpParams.Add(UCase(TargetPath)) ' outpath gpParams.Add(TargetName) ' outname gpParams.Add("") ' whereClause GP.AddOutputsToMap = False GP.Execute("FeatureClassToFeatureClass_conversion", gpParams, Nothing) Catch ex As Exception Throw Finally ReleaseComObject(gpParams) ReleaseComObject(GP) End Try End SubAnd here I 'm stuck. I end up in the catch of the method, and the GP.getmessage(3) gives me the following feedback:ERROR 000732: Input Features: Dataset part1Name.part2Name_Part3Name does not exist or is not supported.
However the mentioned Dataset does exist and can be opened with the created .SDE file when used in ArcCatalog.
So thank you in advance for reading this far, and I would be very happy if somebody could point me at my error or if someone could tell me a better solution.
Martijn
