ArcSDE data does not loaded in ArcGIS Runtime application
I'm developing an application that uses ArcGIS Runtime for WPF. The application should display a couple of layers from a map package (MPK file). The map packages is referencing to a SQL Server Enterprise Geodatabase, using ArcSDE application server, and it is located on the organization server.
These are the setting of the map package:
When I test the application on the server machine everything works fine, but on client machines (which have no ArcGIS, SQL Server, etc.) the map opens but doesn't display any data.
Any idea why the layers are not loaded? Am I missing something?
