ArcPy inconsistently accepts SQL queries for MakeFeatureLayer or SelectLayerByAttribu
I need to buffer a subset of features in a particular feature class. To do this, I am first creating a feature layer (using a SQL query to select only what I want), and then running Buffer. So my ArcPy script includes this little function to buffer my handful of feature classes:
def funcBuffer(inFeature, outFeature, bufDist, querySQL): arcpy.MakeFeatureLayer_management(inFeature, "tempLayer", querySQL) arcpy.Buffer_analysis("tempLayer", outFeature, bufDist, "FULL", "ROUND", "ALL", "")This works perfectly on most of my feature classes. However, there is one that fails. The Python error is:
ERROR 000230: Failed selecting with "OH_UG" = 'UG'
The help page for that error suggests that the SQL query is invalid. However,
  • the field OH_UG exists, and there are some features with the value "UG"
  • it successfully validates in Query Builder
  • I can use it to Select by Attribute with no problem (python snippet from within ArcMap: arcpy.SelectLayerByAttribute_management("TransmissionLines","NEW_SELECTION","OH_UG = 'UG'"))
  • similarly structured queries work on other feature classes
I've tried different ways of passing the SQL query and all fail: '"OH_UH" = \'UG\'', 'OH_UH = \'UG\'', """ "OH_UG" = 'UG' """
I revised the script to do the selection after making the feature layer:
def funcBuffer(inFeature, outFeature, bufDist, querySQL): arcpy.MakeFeatureLayer_management(inFeature, "tempLayer") arcpy.SelectLayerByAttribute_management("tempLayer", "NEW_SELECTION", querySQL) arcpy.Buffer_analysis("tempLayer", outFeature, bufDist, "FULL", "ROUND", "ALL", "")and now MakeFeatureLayer works, but SelectLayerByAttribute throws ERROR 000358: Invalid expression -- still a complaint regarding invalid SQL.
I attempted to select using a different (numeric) field in the table, and am still getting the same 000358 error.
So I am not sure what's going wrong -- is it the SQL, is it the particular feature class, is it gremlins? How can I work around the problem in ArcPy?
