I have the following question about formatting a string which I use to create output file names.
I loop a SearchCursor to create .png file. I extract two columns form the cursor e.g. "GMS_ID" and "ID". (codepart - with arcpy.da.SearchCursor("dbk_object_test_SpatialJoin2",['GMS_ID','ID','SHAPE@']) as cur
Then I concatenate the two columns like:
vakkrt_name = str(row[0]) + "_" + str(row[1])
Almost at the end I use:
outpng = r"D:\arcpy\output\DBK_" + format(vakkrt_name) + ".png"
to create the file reference and after that I use:
arcpy.mapping.ExportToPNG(mxd, outpng,df, df_export_width=1600, df_export_height=1200, resolution=200)
to really create the file on disk.
The result is something like:
Can you help me by disabling the decimal point probably by using the Format method.
Kind regards.
Kind regards.
