ArcPy - Change Dataframe Projection of .MXD, using values from Calculate UTM Zone?
I have a polygon shape file.
I used ArcPy scripts to:
  • add a new field to the shape file
  • use Calculate UTM Zones on each polygon.
It spits out UTM projection information into the field I've added.
I would like to use a cursor to go through each row of the polygon shapefile's attribute table, using this added field.
For each row in the field, the cursor would:
<ul>Change the projection of the entire data frame in the .MXD to the UTM projection in the calculated UTM field for that polygon
