I am attempting (and failing) to add an image to a map layout using ArcObjects via Python comtypes. I do need to run this outside of ArcMap (i.e. not in the ArcMap Python window).
The basic idea is: open mxd, place jpg in layout, save/close mxd.
Python solution preferred, but I would also accept a similar workflow in VB.NET.
Using ArcGIS 10.2.2, Python 2.7.5
Script:
from comtypes.client import GetModule, CreateObjectfrom Snippets import GetLibPath, InitStandalonedef CType(obj, interface): """Casts obj to interface and returns comtypes POINTER or None""" try: newobj = obj.QueryInterface(interface) return newobj except: return Nonedef main(): InitStandalone() modCarto = GetModule(r"C:\Program Files (x86)\ArcGIS\Desktop10.2\com\esriCarto.olb") modGeom = GetModule(r"C:\Program Files (x86)\ArcGIS\Desktop10.2\com\esriGeometry.olb") modArcMapUI = GetModule(r"C:\Program Files (x86)\ArcGIS\Desktop10.2\com\esriArcMapUI.olb") modFramework = GetModule(r"C:\Program Files (x86)\ArcGIS\Desktop10.2\com\esriFramework.olb") app = CreateObject(modFramework.AppROT, interface=modFramework.IAppROT) mxDoc = CType(app.Item(0).Document,modArcMapUI.IMxDocument) layout = mxDoc.PageLayout graphicContainer = CType(layout, modCarto.IGraphicsContainer) pictureElement = CreateObject(modCarto.JpgPictureElement, interface=modCarto.IPictureElement) envelope = CreateObject(modGeom.Envelope, interface=modGeom.IEnvelope) envelope.PutCoords(0, 0, 5, 5) pictureElement.Geometry = envelope pictureElement.ImportPictureFromFile(r'C:\junk\happy.jpg') iElement = CType(pictureElement,modCarto.IElement) graphicContainer.AddElement(pictureElement,0) # ERROR HERE #graphicContainer.AddElement(iElement,0) app.Item(0).SaveDocument()if __name__ == '__main__': main()Traceback (whether attempting to add pictureElement or iElement):
Traceback (most recent call last): File "C:\Scripts\arcobjects_add_jpeg.py", line 54, in main() File "C:\Scripts\arcobjects_add_jpeg.py", line 47, in main graphicContainer.AddElement(pictureElement,0)COMError: (-2147024809, 'The parameter is incorrect.', (None, None, None, 0, None))Full disclosure: I am absolutely new with ArcObjects, so whether or not I am handling/creating/juggling objects between interfaces correctly, I am not sure, but I think I'm close.
Script:
