Arcobjects java samples AutomationException: 0x80040112
Been trying to run arcgis java samples through eclipse on Win7x64 machine. I am using JRE provided in developer kit. All the samples fail at below code
if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeEngine)== esriLicenseStatus.esriLicenseAvailable) { aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine); }java.lang.RuntimeException: AutomationException: 0x80040112 - Sample failed: AutomationException: 0x80040112 - at com.esri.arcgis.interop.Ocx.(Unknown Source) at com.esri.arcgis.controls.MapControl.(Unknown Source) at com.esri.arcgis.beans.map.MapBean.a(Unknown Source) at com.esri.arcgis.beans.map.MapBean.(Unknown Source) at arcgissamples.graphicstracker.EngineVisualApp.display(EngineVisualApp.java:85) at arcgissamples.graphicstracker.EngineVisualApp.main(EngineVisualApp.java:64) at arcgissamples.loadsample.Main.main(Main.java:26)Caused by: AutomationException: 0x80040112 - ... 7 moreI am using trial license of Advanced Desktop (single user), this seems to be a license problem , any idea how can i make those samples work with desktop licenses.
The aoaInit.initialize should not execute if engine license is not available, but still it does secondly If I initialize with esriLicenseProductCodeAdvanced , there is a crash outside the JVM
# A fatal error has been detected by the Java Runtime Environment:## EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x7e1e1790, pid=12928, tid=3848## JRE version: 6.0_45-b06# Java VM: Java HotSpot(TM) Client VM (20.45-b01 mixed mode windows-x86 )# Problematic frame:# C [ntvinv.dll+0x11790]
