This is an issue I have been trying to tackle for a while and decided to reach out for help. I am creating an ESRI ArcGIS Desktop Add-In that allows the user to draw a polygon and then have it added to the map. I am able to capture the polygon and add it to the map, the issue is the transparency. Currently and by default it is 100% opacity and solid. I want to make it around 50% opacity so the user can see the data behind it.
Here is the code I have so far:
public static void AddPolygonToMap(IActiveView ActiveViewInstance, IGeometry NewGeo) { //Local Variable Declaration var fillShapeElement = default(IFillShapeElement); var element = default(IElement); var graphicsContainer = default(IGraphicsContainer); var simpleFilleSymbol = default(ISimpleFillSymbol); var newRgbColor = default(IRgbColor); var lineSymbol = default(ILineSymbol); //Use the IElement interface to set the Envelope Element's geo element = new PolygonElement(); element.Geometry = NewGeo; //QI for the IFillShapeElement interface so that the symbol property can be set fillShapeElement = element as IFillShapeElement; //Create a new fill symbol simpleFilleSymbol = new SimpleFillSymbol(); //Create a new color marker symbol of the color black; newRgbColor = new RgbColor(); newRgbColor.Red = 0; newRgbColor.Green = 0; newRgbColor.Blue = 0; //Create a new line symbol so that we can set the width outline lineSymbol = new SimpleLineSymbol(); lineSymbol.Color = newRgbColor; lineSymbol.Width = 2; //Setup the Simple Fill Symbol simpleFilleSymbol.Color = newRgbColor; simpleFilleSymbol.Style = esriSimpleFillStyle.esriSFSHollow; simpleFilleSymbol.Outline = lineSymbol; fillShapeElement.Symbol = simpleFilleSymbol; //QI for the graphics container from the active view allows access to basic graphics layer graphicsContainer = ActiveViewInstance as IGraphicsContainer; //Add the new element at Z order 0 graphicsContainer.AddElement((IElement)fillShapeElement, 0); //Show the new graphic ActiveViewInstance.Refresh(); }I know that this is possible somehow and I am sure it's just a line or two missing but any help would be much appreciated.
V/r,
Josh
V/r,
Josh
