In my map I have a layer named PARCEL, when create new feature on this layer, the attribute window will open automatically. There are 2 attributes in this layer: PARCEL_ID and SUB_ID.
Since the PARCEL_ID is the left part of SUB_ID, I intend to display the PARCEL_ID value in SUB_ID field after user input the PARCEL_ID value, this is to minimize user key in wrong information.
Is there a way to do this without a customized editor tool?
I am using vb.net arcobjects 10.2.2.
EDIT1
The reason for use the attribute window in editor is when I tried to use update feature, it didn't work.
Actally my basic idea is after user create new feature:
(1) use max OBJECTID to identify the new created feature
(2) provided a window to ask user to input the PARCEL_ID and SUB_ID of the new created feature
(3) use feature.store to update the PARCEL_ID and SUB_ID values
But I failed to make it work. My code is like followings:
Private Sub GetMaxFID() Try Dim pMxDoc As IMxDocument, pFLayer As IFeatureLayer Dim pCursor As ICursor pMxDoc = My.ArcMap.Application.Document Dim pMap As IMap Dim pActiveView As IActiveView pMap = pMxDoc.FocusMap pActiveView = pMxDoc.FocusMap Dim layerNum = GetIndexNumberFromLayerName(pActiveView, My.Settings.ParcelLayer) pFLayer = pMxDoc.FocusMap.Layer(layerNum) pCursor = pFLayer.Search(Nothing, False) If TypeOf pCursor Is IFeatureCursor Then Dim pData As IDataStatistics = New DataStatisticsClass pData.Field = "OBJECTID" pData.Cursor = pCursor Dim pStatResults As IStatisticsResults = pData.Statistics newOBJECTID = pStatResults.Maximum End If Catch ex As Exception logger.Error(ex.ToString) End TryEnd SubProtected Overrides Sub OnClick() Try Dim pMxDoc As IMxDocument Dim pMap As IMap Dim pActiveView As IActiveView pMxDoc = My.ArcMap.Application.Document pMap = pMxDoc.FocusMap pActiveView = pMxDoc.FocusMap Dim layerNum = GetIndexNumberFromLayerName(pActiveView, My.Settings.ParcelLayer) Dim pFLayer As IFeatureLayer pFLayer = pMap.Layer(layerNum) GetMaxFID() Dim featureClass As ESRI.ArcGIS.Geodatabase.IFeatureClass = pFLayer.FeatureClass If featureClass Is Nothing Then Return End If Dim feature As IFeature = pFLayer.FeatureClass.GetFeature(newOBJECTID) ' is this line correct? If feature Is Nothing Then Return End If Dim objectIDFieldIndex As Integer = pFLayer.FeatureClass.FindField(newOBJECTID) feature.Value(1) = "test123" 'This line I want to set the PARCEL_ID of the new created feature. 'is it correct to use .value(1) here? what should be the value of (1) in this line? feature.Value(2) = "test123-12" 'This line I want to set the SUB_ID of the new created feature. 'is it correct to use .value(2) here? what should be the value of (1) in this line? feature.Store() 'MsgBox("update finished") Catch ex As Exception logger.Error(ex.ToString) End TryEnd SubI believe there is something wrong with my code, how can I make it work?
EDIT1
