Arcmap 10.3 won't display 3 layer line symbols in data or layout view
I ran into a problem when I was attempting to create a simple 3-layer custom line symbol. From bottom to top the layers were a wide solid line, a slightly thinner solid line, and a dashed line. In the symbol property editor this displays correctly. In the table of contents next to the map display the symbol also displays correctly. On the actual map the top most layer of the symbol is omitted in both layout and data view. I thought it might be a problem with altering pre-existing symbols, so I changed it to one of the default symbols (expressway), which is a thin black line atop a thicker yellow line atop a thicker black line. Again, the first layer (the thin black line) simply doesn't appear. It doesn't matter if I adjust the symbol size, or zoom in in either view. What am I doing wrong?
