ArcGIS XML Import Failed - how to find out why it failed?
I am creating an ESRi XML Workspace document in some of my own C# code. The XML doc that is produced validates against the GdbExchange.xsd schema provided by ESRI. However, when I use ArcCatalog to import the XML document into a newly created Personal Geodatabase (.mdb) I get the following error:
Import xml data failedFDO error: -2147186428 [XML parse error: Unspecified error [Line: 415, column: 23].]The line and column indicated above are:
... PointInspections ...(Column 23 is after the closing angle bracket, ">", an the line marked "< !-- THIS LINE -->")
Given that the XML document is valid, how can I get more useful information from ArcGIS?
(There is a somewhat similar question asked here: Importing XML file in ArcGIS failed, but that didn't have a resolution that worked for me...)
