I have an application that allows the user to add a point (in this case, pipe breaks) and snap to a line (water main). I have been asked to pre-populate one of the attributes in the point feature with the same attribute from the line that it is snapped to. Simple enough, theoretically, yet complicated, I believe, programmatically. I should also mention that I am not a good programmer. I am also using the GitHub CMV template, but since this is so outside the realm of CMV, I did not post there.So, has anyone done this?
