A project template is a customized starting state for a project. It can include maps, scenes, layouts, databases, folder connections, and other items. Any configuration of a project that you want to reuse can be saved as a project template.
One reason to create project templates is to standardize practices within a workgroup or organization. For example, you can ensure that maps, scenes, and layouts have a consistent appearance, use the same datasets, and apply the same symbology. Another reason is to tailor the user interface for specific user roles. For example, you can make sure that a new project contains toolboxes with tools needed for certain tasks or that certain databases or folder connections are included.
Contents:
Open the project in ArcGIS Pro
Share the project as a project template in ArcGIS Pro
View the project template in your portal in ArcGIS Pro
Create a project based on the template in ArcGIS Pro
[h=3]Learn the Basics of ArcGIS Pro:[/h]ArcGIS Pro 01: Introducing ArcGIS Pro
ArcGIS Pro 02: Create a project in ArcGIS Pro
ArcGIS Pro 03: Navigate maps and scenes in ArcGIS Pro
ArcGIS Pro 04: Add data to a project in ArcGIS Pro
ArcGIS Pro 05: Explore your data in ArcGIS Pro
ArcGIS Pro 06: Create a project template in ArcGIS Pro
ArcGIS Pro 07: Import an ArcMap document into ArcGIS Pro
ArcGIS Pro 08: Convert a map to a scene in ArcGIS Pro
ArcGIS Pro 09: Symbolize map layers in ArcGIS Pro
ArcGIS Pro 10: Label map in ArcGIS Pro
ArcGIS Pro 11: Share a web map in ArcGIS Pro
ArcGIS Pro 12: Make a layout in ArcGIS Pro
GIS English 2018
credit : esri
Contents:
GIS English 2018
credit : esri
