I am using Operations Dashboard of ArcGIS and I would like to add a widget which count the occurrence of a text value "DAMAGED" in a field ("STATE"). I only found the way to access numeric attributes, but not text ones. I also tried with the widget "Interrogation" (I hope the traduction is right), but I am supposed to start an operation to find the desired number. Rather, I'd like to have a number showing wothout any action. I thought using a filter on that field would do the trick, but this seems only possible for numeric data as I said.
As my field "STATE" can only have two values ("WORKING" or "DAMAGED"), I am aware I can change to a numeric type of field (1 or 0), but this solution would not be as descriptive as the text way, and I would prefer not to change it. Does anyone know how to do this with the "standard" Operations Dashboard (not entering the "developer side")?
To give an overview of what I am doing: I created a point feature representing the public lights of a city (data are invented); I added the field "STATE" which has a domain to only allow the choice between the two attributes "WORKING" and "DAMAGED"; I published the feature to AGOL as feature service. At the end I would like to change the attribute of some lights from "WORKING" to "DAMAGED" with Collector, and see a sort of warming (a count actually) using a widget in Operations Dashboard.
