ArcGIS map service layer not loading properly
I'm at a total loss. My initial problem was an issue with the layer not loading at all when the page was set to the full extent, despite having changed the Min/Max Scale settings generously when publishing the map service. I corrected this by rectifying the Scale settings in JavaScript:
landBaseLayer.on("load", function() { landBaseLayer.minScale = 0; landBaseLayer.maxScale = 0; }); I now have a problem with the layer not loading when entering the page. It loads when I zoom in, and the loaded subset will remain visible when I zoom back out, but everything around it will remain blank. What am I doing wrong? Sorry, I'm totally new to this. I'm using a cached map service, with a Max Record Count of 10,000 (the layer contains just over 7,000 points). The following is the entire code.
Identify with Popup html, body, #map { height:100%; width:100%; margin:0; padding:0; }
