ARCGis LayerToKML Skips Feature Layers and Doesn't Process Layers in Group Layers
I am using ARCGis desktop and have written a quick conversion program to convert my layers to kml but I ran into some issues. It seems the only layers it can process correctly are group layers.
When it processes the group layers I am missing all the feature layers included in the group layer in the resulting doc.kml. It's also failing on feature layers with an error that says it's not a layer with the following message: ERROR 000840: The value is not a Layer. When I know it's a layer, I can pull it up in ARCMap and, indeed, ARCMap agrees with me that it's a layer. I can use the MapToKML function without issue but I need to control my layers individually so I was hoping I can generate KML for each individual layer on a map.
Thanks in advance for any help you can provide.
Here is my source code:
static void Main(string[] args) { IMapDocument mapDocument = new MapDocumentClass(); IPage page; string mapFilename = @"c:\maps\BaseMap_NAD83_SD_StatePlane_Plumes_Scott.mxd"; Console.WriteLine("Initializing GEO..."); Geoprocessor GP = new Geoprocessor(); if (mapDocument.get_IsMapDocument(mapFilename) && mapDocument.get_IsPresent(mapFilename)) { Console.WriteLine("Loading map..."); mapDocument.Open(mapFilename, ""); page = mapDocument.PageLayout.Page; IMap map; for (int iMapIndex = 0; iMapIndex < mapDocument.MapCount; iMapIndex++) { map = mapDocument.get_Map(iMapIndex); Console.WriteLine("Converting layers for map {0}...", map.Name); ILayer layer; for (int iLayerIndex = 0; iLayerIndex < map.LayerCount; iLayerIndex++) { layer = map.get_Layer(iLayerIndex); ConvertLayerToKML(GP, layer as ILayer2); Marshal.ReleaseComObject(layer); } Marshal.ReleaseComObject(map); } } mapDocument.Close(); Marshal.ReleaseComObject(mapDocument); } private static string[] ConvertLayerToKML(Geoprocessor GP, ILayer2 layer) { string [] messages = new string[] {}; string layerName = layer.Name; LayerToKML layerToKML = new LayerToKML(); layerToKML.layer = layer; layerToKML.layer_output_scale = 10000; layerToKML.out_kmz_file = string.Format("{0}.kmz", layerName); Console.WriteLine("Converting layer {0}", layerName); object result = GP.Execute(layerToKML, null); messages = new string[GP.MessageCount]; for (int i = 0; i < GP.MessageCount; i++) { messages = GP.GetMessage(i); } return messages; }
