New to GIS and ArcGIS.
I am trying to use the javascript API setDefinitionExpression to limit the output of a FeatureLayer on the map; however, the result set returned by the function is incorrect. The function returns only one result set but when I try to run the same query on the either the ArcGIS server or the database server, there are 6 results.
Anyone know why this is the case?
I am using SQL Server 2012 and following is the code I am using:
var layer1 = new FeatureLayer(path + "/arcgis/rest/services/MammalDistributionMapOIMap/MapServer/0", { outFields: ["*"], opacity: 0.5});var speciesID = document.getElementById("speciesID").value;stringquery = "species_id = " + speciesID;layer1.setDefinitionExpression(stringquery);
