ArcGIS Administrator crashes with endless loop on extensions
I'm seeing a strange problem in the ArcGIS Administrator for Desktop. The Availability tab is crashing the application, with an endless loop listing 3D Analyst (which doesn't appear to be fully enabled). Both 3D Analyst and Spatial Analyst should be licensed.
ArcGIS Desktop functions normally, so the floating LM is working - but 3D and Spatial Analyst are listed as "not available". The application freezes and I need to force-close it.
I'm running Windows 7 on a Mac, using Parallels (not sure if that makes a difference). Interestingly this exact problem occurs on 2 Macs using the same setup.
Before I uninstall the LM, is there anything I should test or check?
