I have highways labeled with the standard shield and route number on it. For my main data frame the labels come up correctly. I also have 4 inset maps where only the number will show up, not the shield when exporting to a file (any type).
Here are some things that I tried that did not work:
Just to clarify, the shields (text background) shows up in the layout screen when editing the map but not in the exported product after exporting the map to a .pdf or other extension.
The version of ArcGIS being used is 10.1 SP1. I cannot upgrade or change the installation.
Suggestions tried:
It appears that ArcGIS will hide (or not draw) background symbols that are smaller than a certain size compared to the map (% or ratio). When I made the print size smaller (it was originally 34x40 inches) or the symbols larger, the shields showed up.
Does anyone know how to change this option on ArcGIS and possibly show all symbols regardless of size?
Following comment suggestions, the links provided in this forum post did not help.
- Exporting the labels to annotation
- Creating replacement graphics (in each inset's data frame view)
- For each of the above, using .png background instead of .emf
Suggestions tried:
- Deleting the main dataframe, then exporting - same result
- Moving the inset dataframe to a new document
- http://support.esri.com/en/knowledgebase/techarticles/detail/28548
- http://support.esri.com/en/knowledgebase/techarticles/detail/30753
- http://forums.esri.com/Thread.asp?c=93&f=1731&t=235317
- http://forums.esri.com/Thread.asp?c=93&f=1731&t=178684
- http://support.esri.com/en/knowledgebase/techarticles/detail/17783
