I am looking at forest loss in Central and South America within protected and unprotected areas. So I have a binary raster (0 or 1) for forest in 2000 and another raster for forest in 2013. I want to use Zonal Statistics as Table to look at forest loss in each country in protected and unprotected areas (which I have a polygon shapefile for). However, Zonal Stats as Table fails saying it couldn't build attribute table.
When I try to use the Build Raster Attribute Table tool it fails and gives the following error: "Error 000049: Failed to build attribute table." Clicking on the error it says that the rasters need to be integer and single band. But both of my rasters are in GRID format and are single-band, unsigned integer (8 bit).
When I tried clipping the rasters (~500-600MB) into smaller pieces, one for Central America (CA) and one for South America (SA), then the attribute table was automatically built for CA (~60MB), but not SA (~300MB). With the attribute table for CA, I was able to complete my analysis with Zonal Stats as Table. Unfortunately, the Build Raster Attribute Table still fails for the clipped SA raster.
I figured that maybe the raster is still too big, so I clipped the SA raster into two pieces (133MB and 174MB), however the tool still fails on both. I could keep clipping the raster until it is small enough, but that is extremely annoying and inconvenient for the rest of my analysis. Am I doing something wrong with Building the attribute table? There aren't really many options in the tool besides input raster and then overwrite or not (I've tried both ways, doesn't matter).
I've tried turning off Background Geoprocessing, removed and re-added the rasters, tried restarting ArcGIS, and the computer, but same result. Could this be a problem with ArcMap 10.3? I could have sworn that I've dealt with larger rasters than 600MB before in earlier versions, and it was slow but still worked.
