ArcGIS 10.2.2 Mxdperfstat
I'm trying to test an mxd with mxdperfstat.
I want to test several scales, but as soon as I provide a scale over 500, the program simply quits.No Error warning. It just stops working.If I provide several scales at once (250;500;800;1000) it tests the 250 and 500 and then stops.
I use ArcGIS 10.2.2 and the according mxdperfstat10.2.exe.Thats how I call the programm:mxdperfstat10.2.exe -mxd F:\Path\test.mxd -scale 250;500;800;1000 -xy 4348929;5498749 -width 1000 -height 1000
The end of the console output looks like this:
21.11.2014 13:25:18 RunTest:LoadXML21.11.2014 13:25:18 RunTest: ESRI.ArcGIS.ADF.COMSupport.AOUninitialize.Shutdown()21.11.2014 13:25:18 RunTest: ESRI.ArcGIS.ADF.COMSupport.AOUninitialize.Shutdown() Completed21.11.2014 13:25:18 RunTest:Application.Exit()21.11.2014 13:25:18 After RunTest:Application.Exit() No error is documented.
In the resulting .xml report there are only the test values for scale 250 and 500.The behavior is the same for different MXDs.
Any Idea what the Problem could be here?
