I´m using arcgis 10.1 and Archydro tools. During the Catchment Polygon Processing, one of the steps used to define the watershed limits, I get the folowing error:
Executing: CatchmentPolyProcessing Cat "C:\Users\ja007\Desktop\Catchment Polygon Processing\Catchment"Start Time: Mon Jul 06 12:28:54 2015Converting grid to polygons...Executing: RasterToPolygon "C:\Users\ja007\Desktop\catchment grid delineation\cat" C:\Users\ja007\AppData\Local\Temp\arcB34\AH20150706122854\AHTemp.gdb\tmpFB3B NO_SIMPLIFY VALUEStart Time: Mon Jul 06 12:28:56 2015Succeeded at Mon Jul 06 12:35:29 2015 (Elapsed Time: 6 minutes 32 seconds)Dissolving catchments...Executing: Dissolve C:\Users\ja007\AppData\Local\Temp\arcB34\AH20150706122854\AHTemp.gdb\tmpFB3B "C:\Users\ja007\Desktop\Catchment Polygon Processing\Catchment.shp" gridcode # MULTI_PART DISSOLVE_LINESStart Time: Mon Jul 06 12:35:29 2015Sorting Attributes...Dissolving...Succeeded at Mon Jul 06 13:20:08 2015 (Elapsed Time: 44 minutes 38 seconds)Executing: AddField "C:\Users\ja007\Desktop\Catchment Polygon Processing\Catchment" HydroID LONG # # # HydroID NULLABLE NON_REQUIRED #Start Time: Mon Jul 06 13:21:25 2015Failed to execute. Parameters are not valid.ERROR 000732: Input Table: Dataset C:\Users\ja007\Desktop\Catchment Polygon Processing\Catchment does not exist or is not supportedFailed to execute (AddField).Failed at Mon Jul 06 13:21:25 2015 (Elapsed Time: 0,00 seconds)AddFieldGPerror : System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component. at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel) at ESRI.APWR.ApHydro.GDBHelper.AddFieldGP(ApLayer apLayer, String fieldTag, String& exMessage) in C:\Builds\HydroSolutions\10.3_ArcHydro\Sources\ArcHydroTools\src\ApHydro\GDBHelper.vb:line 1339Failed to execute (CatchmentPolyProcessing).Failed at Mon Jul 06 13:21:25 2015 (Elapsed Time: 52 minutes 30 seconds)
How can I can solve this? Is this a processing limitation? I´m considering a huge
