Append tool snippet not working in Pyscripter?
I need to append two shapefiles together. The append tool works within the ArcMap toolboxes AND Python window, but it does not work when copying over the python snippet to PyScripter. It'll completely run through but won't produce values within the fields (all values will be empty or null).
I'm assuming it has something to do with the FieldMapping() objects?
import arcpy arcpy.env.overwriteOutput = True arcpy.env.workspace = r"C:\Users\Documents\ArcGIS\Default.gdb" tc = r"testing_append" changesshp = r"C:\Users\gfrederick\Documents\Scripts\changes.shp" lyr1 = arcpy.MakeFeatureLayer_management(tc, "tc_lyr") lyr2 = arcpy.MakeFeatureLayer_management(changesshp, "change.lyr") arcpy.Append_management(lyr2, lyr1, schema_type="NO_TEST", field_mapping="""RECORDNUM "RECORDNUM" true false false 19 Double 10 18 ,First,#,changes_new,RECORDNUM,-1,-1;TAKENBY "TAKENBY" true false false 50 Text 0 0 ,First,#,changes_new,TAKENBY,-1,-1;SETDATE "SETDATE" true true false 8 Date 0 0 ,First,#,changes_new,SETDATE,-1,-1;SETYEAR "SETYEAR" true false false 4 Text 0 0 ,First,#;MCD "MCD" true false false 50 Text 0 0 ,First,#,changes_new,MCD,-1,-1;RDPREFIX "RDPREFIX" true false false 50 Text 0 0 ,First,#,changes_new,RDPREFIX,-1,-1;ROUTE "ROUTE" true false false 19 Double 10 18 ,First,#,changes_new,ROUTE,-1,-1;ROAD "ROAD" true false false 50 Text 0 0 ,First,#,changes_new,ROAD,-1,-1;CNTDIR "CNTDIR" true false false 50 Text 0 0 ,First,#,changes_new,CNTDIR,-1,-1;FROMLMT "FROMLMT" true false false 50 Text 0 0 ,First,#,changes_new,FROMLMT,-1,-1;TOLMT "TOLMT" true false false 50 Text 0 0 ,First,#,changes_new,TOLMT,-1,-1;TYPE "TYPE" true false false 20 Text 0 0 ,First,#,changes_new,TYPE,-1,-1;RDSUFFIX "RDSUFFIX" true false false 15 Text 0 0 ,First,#,changes_new,RDSUFFIX,-1,-1;LATITUDE "LATITUDE" true false false 19 Double 8 18 ,First,#,changes_new,LATITUDE,-1,-1;LONGITUDE "LONGITUDE" true false false 19 Double 8 18 ,First,#,changes_new,LONGITUDE,-1,-1;FACTOR "FACTOR" true false false 19 Double 8 18 ,First,#,changes_new,FACTOR,-1,-1;AXLE "AXLE" true false false 19 Double 8 18 ,First,#,changes_new,AXLE,-1,-1;AADT "AADT" true false false 9 Long 0 9 ,First,#,changes_new,AADT,-1,-1;UPDATED "UPDATED" true true false 8 Date 0 0 ,First,#;CO_NAME "CO_NAME" true false false 35 Text 0 0 ,First,#;MUN_NAME "MUN_NAME" true false false 40 Text 0 0 ,First,#""", subtype="")
