Any tool to monitor ArcGIS Server Usage
I am using ArcGIS Server 10.1 on AMI instance. I have around 10/12 simple map services (Used query layer in all services)
I want to check performance/time/statistics of map services in ArcGIS Server.
So is their any tool to monitor ArcGIS Services ??
What I found so far :
1.According to http://ideas.arcgis.com their are few third party tools available.
2.Using windows task manager I can monitor only process not the services.
3.In 10.0 version its possible to see the statistics/min ,max time using 'statistics' tool in ArcGIS Server I think in 10.1 its not present
4.Using ArcPy I doubt its possible .Even I tried using ArcGIS ADMIN API for server.
5.Screenshot of windows task manager (javaw.exe taking too much memory but its important to run the ArcGIS Server according to this post)
Any help will be great !!
thanks in advance : )
Update
According to @Alex Tereshenkov answer I downloaded the tool but it work with Web adapter only. We do not have the Web adapter we are using reverse proxy at our end.
Found this useful article for ArcGIS Server to test the load balance using Jmeter
