SQL Server 2008 and up allow you to create a spatial index. If you select records that include a geography or geometry object, a spatial data tab appears that can display up to 5000 points or lines or other shapes. You can select a label column, pan, and zoom. I am trying to debug a road network dataset that has disconnected islands of roads and need to be able to display all the line segments for a given state and label the disconnected ones so I can see where the missing roads are. That means I need to display more than 5000 objects.
Are there any free tools that can do this, including the labeling (color labels would be ok if text labels are not supported)? I have about 250,000 line segments, but anything that can display 50,000 would be okay for my work. A plugin for SSMS would be best, but an external tool would work, too. If there is a C# .NET library, I could use that, too.
