I have a choropleth map which displays crime percentage change. It is plotted from a geodataframe and the choropleth intervals are determined in the background by Python.
Unfortunately, the first label in the legend (for white polygons) shows "0.00 - -50.00" when it is in actual fact starting from -286, not 0. Similarly, the last label shows "30.18 - nan".
How do I change these to "Less than -50.0" and "Greater than 30.18"?
Please see my code below:
f, ax = plt.subplots(1, figsize=(16, 16))PoliceDataMap.plot(column='PercChange', scheme='quantile', k=5, legend=True, axes=ax, colormap='Reds', linewidth=0.2, alpha=0.8)ax.set_axis_off()ax.set_title("Crime Percentage Change between Jan 2011 & Jan 2015", **TitleFont)plt.axis('equal')plt.show()
