I have installed the agent analyst extension for my ArcGis 10.2. I am also following ESRI tutorial (http://resources.arcgis.com/en/help/agent-analyst/). Every model which requires updateDisplay or just update action doesn't work. When I click run and later on initialise - nothing happens and when I click start or step, the program crashes. I got something like this:
https://drive.google.com/file/d/0B6apFdCMCsMbcjhwR2YwT01TTU0/edit?usp=sharing
Do you know how can I fix it?
I think it can be something with refresh files, I followed 2 posts:
So I changed version to 10.2, but in the second post I tried Update 2 option (I don't know how could I do update 1) and it doesn't work. In Refresh.exe.config file, I tried to type in newVersion: 10.2.0.0, 10.2.2.0 and my 10.2.2.3552. Only when I put 10.2.0.0, there is no error - when I am clicking Refresh.exe file after changing Refresh.exe.config. Nevertheless there is a problem in the simulation, which I described above.
- Agent Analyst tool interface will not open on ArcGIS 10.1 (Agent Analyst tool interface will not open on ArcGIS 10.1)
- ArcGIS 10.1 using Repast's Agent Analyst Extension - refresh.exe does not work (ArcGIS 10.1 using Repast's Agent Analyst Extension - refresh.exe does not work)
