I am trying to verify US address using the LOB python library. I am having problems running the script to process a CSV file with address. I am running python using OSX and I dont know what put as in the abspath( what to put here?). I dont know if I should put hte directory or the file name. Also despite having the library already installed into my mac I still get syntax errors importing lob. Can someone take a look at my script and see how I can run it so that I can process my test CSV. The file is found on my desktop and is composed of parsed out addresses.
code is found below:
import sys,ossys.path.insert(0, os.path.abspath('desktop/input.csv')import lobimport csvimport datetimelob.api_key = 'XXX'skipFirstLine = True# Column indices in CSVname = 0amount = 1address1 = 2;address2 = 3;city = 4;state = 5;postcode = 6;country = 'US'try: sys.argv[1]except IndexError: print "Please provide an input CSV file as an argument." sys.exit()# Open input filesinputFile = open(sys.argv[1], 'rU')csvInput = csv.reader(inputFile)# Create output fileserrors = open('errors.csv', 'w')verified = open('verified.csv', 'w')success = open('success.csv', 'w')# Loop through input CSV rowsfor idx, row in enumerate(csvInput): if skipFirstLine and idx == 0: continue # Sanity check sys.stdout.write('.') sys.stdout.flush() # Verify addresses try: verifiedAddress = lob.Verification.create( address_line1 = row[address1], address_line2 = row[address2], address_city = row[city], address_state = row[state], address_zip = row[postcode], address_country = country ) except Exception, e: outputRow = ",".join(row) + "," + str(e)+ "\n" errors.write(outputRow) else: outputRow = row[name] + "," outputRow += row[amount] + "," outputRow += verifiedAddress.address.address_line1 + "," outputRow += verifiedAddress.address.address_line2 + "," outputRow += verifiedAddress.address.address_city + "," outputRow += verifiedAddress.address.address_state + "," outputRow += verifiedAddress.address.address_zip + "\n" verified.write(outputRow) # Create letter for verified addresses try: createdLetter = lob.Letter.create( description = 'Bill for ' + row[name], metadata = { 'campaign': 'billing_statements' }, to_address = { 'name': row[name], 'address_line1': verifiedAddress.address.address_line1, 'address_city': verifiedAddress.address.address_city, 'address_zip': verifiedAddress.address.address_zip, 'address_state': verifiedAddress.address.address_state, }, from_address = { 'name': 'Your Name/Company', 'address_line1': '123 Test Avenue', 'address_city': 'San Francisco', 'address_state': 'CA', 'address_zip': '94107', }, file = open('letter_template.html', 'r').read(), data = { 'date': datetime.datetime.now().strftime("%m/%d/%Y"), 'name': row[name], 'amountDue': row[amount] }, color = True ) except Exception, e: print "Error: " + str(e) + " in " + str(row) else: outputRow = createdLetter.id + "," outputRow += createdLetter.url + "," outputRow += row[name] + "," outputRow += row[amount] + "," outputRow += (createdLetter.to_address.address_line1 if createdLetter.to_address.address_line1 != None else " ") + "," outputRow += (createdLetter.to_address.address_line2 if createdLetter.to_address.address_line2 != None else " ") + "," outputRow += (createdLetter.to_address.address_city if createdLetter.to_address.address_city != None else " ") + "," outputRow += (createdLetter.to_address.address_state if createdLetter.to_address.address_state != None else " ") + "," outputRow += (createdLetter.to_address.address_zip if createdLetter.to_address.address_zip != None else " ") + "\n" success.write(outputRow)errors.close()verified.close()success.close()print "\n"
