Adding Vertical Reference in Python to ArcGIS feature dataset
I am creating a python script to generate a terrain. In the process I am creating two feature datasets. However, in order to successfully create this FD, i need both horizontal and vertical datums. I am able to code the horizontal datum successfully, but unable to input the vertical datum. Although the code does not error out, it does not create the requested feature dataset.
I am using ESRI ArcGIS 10.2 and coding in Python 2.7
Thanks
