Adding postgis layer from python plugin
I try to develop a plugin to add postgis layers to qgis from a plugin as part of learning python.
The code for adding a postgis layer is taken from the cookbook and work fine if I run it from the python console within qgis (If button OK is pressed in dialog box result == 1 and should add my layer to qgis).
But if I run it from my plugin it throws the message NameError: name 'QgsDataSourceURI' is not defined. Why do I get that error running it from the plugin?
Is there a difference how I add a layer from a plugin/inside a function vs from the python console?
def run(self): """Run method that performs all the real work""" # show the dialog self.dlg.show() # Run the dialog event loop result = self.dlg.exec_() # See if OK was pressed if result == 1: # Do something useful here - delete the line containing pass and # substitute with your code. uri = QgsDataSourceURI() uri.setConnection("localhost", "5432", "test", "postgres", "postgres") #set database schema, table name, geometry column and optionaly subset(WHERE clause) uri.setDataSource ("basic", "cities", "geom") # Defining the layer name and layer type for QGIS? vlayer=QgsVectorLayer (uri .uri() ,"cities","postgres")
