Adding Parameter Descriptions to Script Tool
I've made a simple tool that accepts three parameters: an input file (feature class), an output folder (folder), and an output name (string). These are all required input with no filters. The tool's main description correctly displays on the right pane of the tool window in Arc, but the input parameter descriptions are not showing up when their fields are clicked on. I tried editing the Item Description in ArcCatalog, but this only brings up an empty window with nothing to edit. What am I missing here?
This is the tool's
The tool executes successfully.
Ideally I'd like to be able to access/edit documentation completely within the script, but I don't know how to start there. This is all saved within a .xml file somewhere, right? If so, where is that stored?
