I am trying to use os.walk to go through a directory tree, pull out all the .shp files in it, create a grouplayer in the mxd, rename the grouplayer the folder name, then add the layers from that folder to the group. This is because I have a lot of folders with files in them that represent geologic formations and they don't mean anything once seperated from the name of the formation.
From what I read you can't just add a blank group layer in an mxd from python without first creating a blank one and adding that. The problem starts at the for group_name in rename_group_layer loop. It doesn't even make it through to the print group_name test. Basically it just falls out of the loop from what I can tell.
Then I need to figure out how to add the layers from the folder into the renamed group layer. I have two lines commented out that I think are a start, but I haven't gotten it to go through the renaming loop yet. It will rename the first "New Group Layer" if I put that line above the loop to the correct folder name. I am pretty new to python so any help you can give would be greatly appreciated.
import osimport arcpy# Set workspace environment to a folderWS = r'c:\test_define\Appalachian Basin'arcpy.env.workspace = WSmxd = arcpy.mapping.MapDocument(r"c:\test_define\test_python_add3.mxd")df = arcpy.mapping.ListDataFrames(mxd, "layers")[0]print ("#") *80for (path, dirs, files) in os.walk(WS): for name in files: if name.endswith(".shp"): print path print "^^^^^^^^^^^^^^^^^^ path variable" try: layers = arcpy.mapping.ListLayers(mxd) for layer in layers: if layer.isGroupLayer and layer.name == os.path.basename(path): newLayer = arcpy.mapping.Layer(os.path.join(path, name)) arcpy.mapping.AddLayerToGroup(df, layer, newLayer, "BOTTOM") else: groupLayer = arcpy.mapping.Layer(r"c:\test_define\empty_group_layer.lyr") arcpy.mapping.AddLayer(df, groupLayer, "BOTTOM") layers = arcpy.mapping.ListLayers(mxd) for layer in layers: if layer.isGroupLayer and layer.name == "New Group Layer": layer.name = os.path.basename(path) newLayer = arcpy.mapping.Layer(os.path.join(path, name)) arcpy.mapping.AddLayerToGroup(df, layer, newLayer, "BOTTOM")#mxd.save()# print messages when the tool runs successfully print(arcpy.GetMessages(0)) #print ("+") *50 except arcpy.ExecuteError: print(arcpy.GetMessages(2)) except Exception as ex: print(ex.args[0])mxd.saveACopy(r"c:\test_define\test.mxd")
