I'm having an error when I run the model in Add Join (3). Add Join (2) runs well, but when it's running Add Join (3) it fails with Error 999999.I need to join 4 different tables to linhas_150_5km, how do I make it work with "Add Join"? I tried "Join field" but its a permanent join, and in the end I need to remove 2 of the joins. And this is a model that will have different inputs, I can't keep the fields in attribute tables when the inputs are different from the beggining.
