add feature to map in OpenLayers3
I want to add a point to a map but can't seem to do it.
I have this function to create a point:
INPUT:[208, "POINT(-72.7072715090951 41.5953903556503)]"function make_point(input){ var format = new ol.format.WKT(); var point = format.readFeature(input[1], { "dataProjection": new ol.proj.Projection("EPSG:4326") }); point.id=input[0]; return point;}OUTPUT:pn {na: false, va: undefined, yb: Fc, Od: pn, gb: null…} G: Object geometry: E A: Array[2] 0: -72.7072715090951 1: 41.5953903556503Then I add this point to a layer like this:
function make_point_vector_layer(point){ var point_feature = new ol.Feature({ geometry: point, name: 'Point' }); } var point_vector = new ol.layer.Vector({ map : map, source: new ol.source.Vector({ features: [point_feature] }) }); return point_vector;}But I get this error:
Uncaught TypeError: n.J is not a functionDoes anyone know what the problem is?
P.S. This happens after the map has been draw. Like, it's happening after an ajax call.
Thanks in advance for your kind help.
