I want to create a wfs layer in OpenLayers 3. I define it as follow:
sourceVector = new ol.source.Vector({ loader: function(extent) { $.ajax('http://localhost:8080/geoserver/iran/wfs?service=WFS',{ type: 'GET', data: { service: 'WFS', version: '1.1.0', request: 'GetFeature', typename: 'iran:capital', srsname: 'EPSG:4326', bbox: extent.join(',') + ',EPSG:4326' }, }).done(loadFeatures); }, strategy: ol.loadingstrategy.tile(new ol.tilegrid.XYZ({ maxZoom: 19 })), });window.loadFeatures = function(response) { formatWFS = new ol.format.WFS(), sourceVector.addFeatures(formatWFS.readFeatures(response)); };wfs = new ol.layer.Vector({ source: sourceVector, style: new ol.style.Style({ stroke: new ol.style.Stroke({ color: 'rgba(0, 0, 255, 1.0)', width: 2 }) })});But when I run the project, I'm faced with this error:
I created a proxy.cgi file with the following values:
#!C:/Python27/python.exe -u"""This is a blind proxy that we use to get around browserrestrictions that prevent the Javascript from loading pages not on thesame server as the Javascript. This has several problems: it's lessefficient, it might break some sites, and it's a security risk becausepeople can use this proxy to browse the web and possibly do bad stuffwith it. It only loads pages via http and https, but it can load anycontent type. It supports GET and POST requests."""import urllib2import cgiimport sys, os# Designed to prevent Open Proxy type stuff.allowedHosts = ['www.openlayers.org', 'openlayers.org', 'labs.metacarta.com', 'world.freemap.in', 'prototype.openmnnd.org', 'geo.openplans.org', 'sigma.openplans.org', 'demo.opengeo.org', 'www.openstreetmap.org', 'sample.azavea.com', 'v2.suite.opengeo.org', 'v-swe.uni-muenster.de:8080', 'vmap0.tiles.osgeo.org', 'www.openrouteservice.org', 'maps.wien.gv.at', 'localhost:8080']method = os.environ["REQUEST_METHOD"]if method == "POST": qs = os.environ["QUERY_STRING"] d = cgi.parse_qs(qs) if d.has_key("url"): url = d["url"][0] else: url = "http://www.openlayers.org"else: fs = cgi.FieldStorage() url = fs.getvalue('url', "http://www.openlayers.org")try: host = url.split("/")[2] if allowedHosts and not host in allowedHosts: print "Status: 502 Bad Gateway" print "Content-Type: text/plain" print print "This proxy does not allow you to access that location (%s)." % (host,) print print os.environ elif url.startswith("http://") or url.startswith("https://"): if method == "POST": length = int(os.environ["CONTENT_LENGTH"]) headers = {"Content-Type": os.environ["CONTENT_TYPE"]} body = sys.stdin.read(length) r = urllib2.Request(url, body, headers) y = urllib2.urlopen(r) else: y = urllib2.urlopen(url) # print content type header i = y.info() if i.has_key("Content-Type"): print "Content-Type: %s" % (i["Content-Type"]) else: print "Content-Type: text/plain" print print y.read() y.close() else: print "Content-Type: text/plain" print print "Illegal request."except Exception, E: print "Status: 500 Unexpected Error" print "Content-Type: text/plain" print print "Some unexpected error occurred. Error text was:", Eand then I set OpenLayers.proxyHost to OpenLayers.ProxyHost = "proxy.cgi?url";
How can I do in OpenLayers 3 for this problem(I use Apachea in server side)?
XMLHttpRequest cannot load http://localhost:8080/geoserver/iran/wfs?service=WFS&service=WFS&version=1.…3702828511596%2C0%2C6.02966565566021e-11%2C76.43702828517625%2CEPSG%3A4326. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://localhost' is therefore not allowed access.
this problem was in OpenLayers 2, but I solved it as follow:
