I'm pre-processing GPS data to assess possible methods for a planned research. The aim of the research is to use crowd-sourced cycling routes data to plan a cycling paths in an Israeli city.
Currently I'm using my own walks data to form a GIS working process. In short:
One problem is noise routes due to GPS accuracy limitations. The image below gives an example for such noise (Google maps on the background to give context):
I'm trying to think of a way to clean the data, that is to remove the noisy paths (or nodes) an by-pass them with a straight line. The only thing that came in mind is to find self-intersections using arcmap topology; but I'm still looking for more ideas. Note that this process must be automated, since it will be preformed many times (hopefuly some thousands of times).
I'm open to qgis, grass-gis, python, arcmap and R solutions; but mainly looking for an algorithm (workflow).
Any Ideas?
- Data is collected using a mobile app (http://www.sports-tracker.com/dashboard), giving point location (lat,lon), altitude and a timestamp.
- Data is parsed from its .gpx (xml) format using R. Distance in meters, speed and Z values for speed are being calculated.
- Data is written out as polylines (for each walk); that is one line between any two points, to form one polyline shapefile for each route. The output is a .csv file with WKT as the geometry column.
Any Ideas?
