10-digit number with leading digit higher than 1 throws an "out of range" error?
I'm working with some points in ArcMap 10.3 that have specified volumes, and I am plotting them so that the points have graduated symbols. Nothing particularly strenuous. However, I noticed one of my largest observations, at just over 2,200,000,000, was nullified in the table. When I went to change it from to the correct input, it gave me the "the value you have entered is out of range or is not a whole number" error. I can put in 2 billion, but not anything higher than that. I don't know if this is related to the fact that the field type is currently set at "Long" or not, but I'd appreciate some help in finding the root of the issue. Normally I would just exclude the point, but since it's one of the largest it really should be represented on the map.
