دورة Esri ArcGIS Desktop 10.3.1
Esri ArcGIS Desktop 10.3.1 | 893.7 mb
Icecream PDF Converter PRO is a very simple, yet effective software to convert various types of files such as images, documents, ebooks or HTML files to PDF and to convert PDF files to other formats such as JPG, BMP, PNG, TIFF, DOC, ODT, TXT and more. Icecream PDF Converter works in 2 modes: convert To PDF and From PDF. Users can easily switch between these modes with a simple click of a button. The program also provides an easy method of adding files using either Windows Explorer or by drag&drop. If you decide to use Windows Explorer, you can filter files by their types. In From PDF mode, you can only add PDF files, in To PDF mode, there are 5 file filters: all supported formats of files, eBook files, images, documents and HTML.
To PDF mode supports working with password-protected files (under the condition that valid Password (If need) inserted before the conversion). Also it is possible to insert numbers of pages and page ranges of added PDF files that should be converted in order not to work with all the pages of the documents. Along with that, all the added files can be split during the conversion process.
From PDF modes offers advanced settings for quality conversion of file formats such as: DOC, DOCX, XLS, ODT, ODS, HTML, HTM, EPUB, MOBI, FB2, JPEG, JPG to PDF. Users can apply settings for all the files and for each file individually. Settings are divided into 2 categories: File settings and Layout settings. In File settings, users can apply such values as Filename, Title, Publisher and apply a password on the output PDF file.
As for the Layout settings tab, users can change image and page size, margin, position, rotation and orientation of the files. All the changes that are applied to the file can be clearly seen in the preview area in the lower right corner. While converting the added files to PDF, users can choose to merge all them together into a single PDF file. The sequence of the files can be reordered either by means of drag and drop mechanism or with the use of Up and Down arrows in the right side of the programs window.
The conversion process usually takes a few moments and is initiated with a single click of the Convert button. The intuitive interface will guide users to multiple functions of Icecream PDF Converter. The multilingual interface offers a number of languages to choose from.
OS : Windows 8, Windows 7, Windows 2003, Windows 2000, Windows 8, Windows Vista, Windows XP, Windows Server 2008
Language : Multilingual
كود:
http://www.hitfile.net/4h7G/fhejq.Esri.ArcGIS.Desktop.10.3.1.rar.html
