تعلّم نظام التشغيل لينكس Udemy - Learn Linux: Become a Unix Master
صورة: https://u.damasgate.com/001/5/5839mf2vg35f0yk5oyci.png Learn Linux: Become a Unix MasterMP4 | Video: AVC 1280x720 | Audio: AAC 44KHz 2ch | Duration: 1.5 Hours | Lec: 33 | 287 MBGenre: eLearning | Language: EnglishEverything you need to know to be able to do anything possible with a computer, in under 2 hoursDescriptionكورس تعليم نظام التشغيل Linux. وهو أحد الأنظمة المعروفة مثل الويندوز.في هذا المورس الذي مدته ساعة ونصف ستتدرّب عليه وتعرف كيفية التعامل معه.This course is literally all you need and more to master something that isn't UNIX ;). Ultimately, anything extra would be up to you to learn and implement, which a Unix Master would do.Everything you need to know to be able to do anything possible with a computer, in under 2 hoursLinux is an awesome open source operating system kernel. This is a course about a bunch of GNU commands working on a system running with the Linux kernel. Usually called GNU/Linux - which is most of the Linux distributions that are available. If you need to know what a web server is or all the configuration options then this course doesn't have them and won't be for you, but it will give you all the information needed to be able to setup and configure a web serverThis course is literally all you need and more to master something that isn't UNIX ;). Ultimately, anything extra would be up to you to learn and implement, which a Unix Master would do. What is covered in the shell scripting section is enough to build a Turing Machine, if you are familiar with them, which means you could do anything computers can possibly do. (From Wikipedia: "Despite the model's simplicity, given any computer algorithm, a Turing machine can be constructed that is capable of simulating that algorithm's logicFrom time to time there are course announcements made when I run into cool Linux blog posts by other people, and I'll share the link and say a little about it. All the commands covered are in the PDF files available to anybodyصفحة الكورسPHP:----------https://www.udemy.com/learn-linux-become-a-unix-master/----------التحميل رابط واحد فقطhttps://bdupload.info/0bszntoq1533h...4895attwhttps://racaty.com/zxvz259v7dfjGoogle Drive + Kbagi + Filecloud.io + Filesupload.org + Uppit.iohttp://multiup.org/en/mirror/9b7e4b79492c10d21d86882a937d6fae/r2r9a.rar
