Wflow - hydrological simulations
wflow consists of a set of python programs that can be run on the command line and perform hydrological simulations. The models are based on the PCRaster python framework. In wflow this framework is extended (the wf_DynamicFramework) so that models build using the framework can be controlled using the API. Links to BMI, OpenMI and OpenDAP have been made.
Download Wflow as a plugin for Deltashell
https://github.com/openstreams/wflow/releases/download/2015.02.3/Wflow2015.02.master-64-wflow_kernel_deltashell.zipDeltashell :
http://oss.deltares.nl/documents/131795/345074/delta-shell-1.0.24589-EAP.zipOnly use this for the wflow.Deltashell plugin.
Copy the contents of this zip to:
.\plugins\DeltaShell.Plugins.WFlow\wflow_kernel\
